Most popular and voted for products
  • Thank you received: 6
12 years 7 months ago #61849
1. Is there a module to display highest ranked/most voted products?
also maybe conditions, so you can create modules for most voted products in last year, month, week, day...
2. Is there a module to display the most bought products?
3. Is there a module to display the most view products?
  • Thank you received: 13538
12 years 7 months ago #61955
1. Yes. You can use the normal HikaShop content module for that. Just set the ordering column option to product_average_vote and the ordering direction option to DESC.
2. Yes. You can use the normal HikaShop content module for that. Just set the ordering column option to product_sales and the ordering direction option to DESC.
3. Yes. You can use the normal HikaShop content module for that. Just set the ordering column option to product_hits and the ordering direction option to DESC.
11 years 10 months ago #107839
Hi, my question is related to this topic.
Is it possible to have the user's top buys? One module with the most bought products by a determined user, when he is logged in?
And a module with something like, "who bought this product, also bought..", have some kind of cart analysis/comparison, and suggestions?
Thanks in advance.
11 years 10 months ago #107876
For your first question, there is no module for that.
For the second point, you can add related products to your products in order to display suggestions on the product page. There is however no "people who bought this product, also bought.." module
11 years 5 months ago #131577
Dear Nicolas,
do you confirm that I can list the most voted (or sold etc) products inside a specific category but not inside all categories at the same time?
11 years 5 months ago #131628
Both are possible with a HikaShop products listing menu/module provided that you configure its hikashop options accordingly.
11 years 5 months ago #131679
ok thanks.
Is there a way to reset the best seller list as it is populated by products purchased during website functioning tests and not by real sales?
thanks for your help
11 years 5 months ago #131682
Yes. Create a new mass action with an action "update the value" on the "product_sales" column and set its value to 0. Then simply run the mass action and that will reset the best sellers.
11 years 5 months ago #131698
Amazing product and amazing support!
thanks
