Problem with width auto in chrome
  • Thank you received: 24
12 years 7 months ago #65151
I dont know since when i have this problem but if you go to www.lacestamagica.com surfing on chrome, the width:auto sets the width to the 100% and brokes image dimensions, you can see it surfing on ie or firefox, any help?
12 years 7 months ago #65153
Ok i found the problem and i left the answer if anyone has the same problem. if you set max-heigt:x px; and width:auto; you need to set height:auto; for chrome to redimension the image in proportion.
10 years 11 months ago #154231
What css file did you edit to achieve this?
Abstract Image Group | Fulfilling all of your large format printing needs!
10 years 11 months ago #154232
I usually use yootheme so i do it in my custom.csd but you can do it in the hikashop frontend css wich can be modified in configuration display
Time to create page: 0.144 seconds
