help with filters and searching
12 years 3 months ago #83532
Hi again,
Can you change the "Category" option through your price filter configuration page ? (you can set it to "product category" for example).
12 years 3 months ago #83581
I did it but with the same result. It does NOT work. Not one product comes out of the filter.
Thanks, Constantin
Last edit: 12 years 3 months ago by cosg2004.
12 years 3 months ago #83601
Hello Mohamed,
It seems that I have the same problem on my web site. I also have the business edition. If I use the filters included in the top of the product list, it works fine (my filter is on manufacturer). But if I use the filter module, the filter does not work at all, it returns 0 items.
I can provide a link to our site if it can help.
Last edit: 12 years 3 months ago by noixdarec.
12 years 3 months ago #83809
Hi Noixdarec,
Can you give me a temporary access to your back-end through PM ? Then I 'll maybe be able to found out where the problem were coming from.
Last edit: 12 years 3 months ago by Mohamed Thelji.
