product not found when adding to cart from filter
12 years 1 month ago #68790
on my site i have filter button. This works great. I enter the search item eg beans then it displays all products with beans.
However when I add product to cart I get Product not found.
Problem can be shown here :
go to www.britishfoodabroad.co.uk
enter beans in search for example
click add to cart
you will then get the error Product Not Found
Any ideas why?
12 years 1 month ago #68855
can anyone help on this issue?
  • Thank you received: 13378
12 years 1 month ago #68910
It sounds like a problem of redirection URL.
Normally you should have this line:
<input type="hidden" name="return_url" value="<?php echo urlencode(base64_encode(urldecode($this->redirect_url)));?>"/>
near the end of the file "add_to_cart_listing" of the view "product" via the menu Display->Views.
If that's the case, change it to:
<input type="hidden" name="return_url" value=" www.britishfoodabroad.co.uk/index.php/pr...ts/product/listing"/ >
and that should solve the problem.
If you don't have it, please give the content of that file. And check that it's the latest version of the file (you can look at the header of the file at the top for the version number). If not, please delete the customization on the listing of views and try again.
12 years 1 month ago #69007
i changed the line as above but still get product not found
12 years 1 month ago #69032
Please make sure that you're editing the file for your front end template and not another template or you won't see the change.
12 years 1 month ago #69060
i checked the template and inserted the code but am still getting product not found. it works only if you first click on the products link then search for example for beans, add a search result to cart and it is okay. Problem is when you click on Shop by category then enter a search. When the results are shown and you click add to cart on a search result then it displays Product Not Found.
