Export products - description ends in Product ID
12 years 2 days ago #77916
I have tried to export my products and view them in excel, I open up excel, import the csv using ; as the delimiter but the first 1000 lines contain the product description in the product id column, then after all the descriptions are exhausted, the rest of the csv file looks fine and everything is where it should be. Maybe im importing into excel incorrectly?
Any help greatly appreciated.
Dave
12 years 2 days ago #77925
Yes I think that the problem come from excel, try to open the csv file with another program.
The following user(s) said Thank You: dlarge
12 years 1 day ago #78242
Thanks - it appeared to work ok in google docs spreadsheet.
Can anyone recommend a good csv file viewer so I can sort columns and edit properly?
Dave
  • Thank you received: 4028
12 years 1 day ago #78261
You can use OpenOffice.
It can open and create CSV files.
11 years 11 months ago #78613
Thanks - Completely forgot about open office!
