Setting up a better looking filter module
  • Thank you received: 16
13 years 5 months ago #97431
Having an horizontal "Top content area" filter modules with about 7-10 filters to put I want to get the aligned so to avoid chaotic looking.
How should I invoke trough PHP each filter to put them inside a table cell?
for example, I have a filter named "AlturaElevacion", what would be the code to get it inside a cell?
13 years 5 months ago #97493
The view to edit is "product / filter" in Display < Views. It will change too the filters displayed on top of a product listing.
It require PHP knowledges.
13 years 5 months ago #97505
I'm not an advanced PHP coder but I'm used at tweaking view files.
Now the filters get rendered through a foreach loop that picks them one by one. I simply would like to know how to replace this foreach system for a custom made one where I have to name each filter one by one. This way I can put them exactly where I want.
My question is:
How is written the basic piece of code in a view that would render a filter named "AltureElevacion"
  • Thank you received: 14221
13 years 5 months ago #97567
The filters are not displayed with a foreach on that view file.
They are displayed like that:
while($count<$this->maxFilter+1){
			$height='';
			if(!empty($filters[$count]->filter_height)){
				$height='height:'.$filters[$count]->filter_height.'px;';
			}else if(!empty($this->heightConfig)){
				$height='height:'.$this->heightConfig.'px;';
			if(!empty($html[$count])){
				<div class="hikashop_filter_main hikashop_filter_main_<?php echo $filters[$count]->filter_namekey; ?>" style="<?php echo $height; ?> float:left; width:<?php echo $widthPercent*$filters[$count]->filter_options['column_width']?>%;" >
					<?php //echo $this->filterClass->displayFilter($this->filters[$count], $this->params->get('main_div_name'), $this);
						echo '<div class="hikashop_filter_'.$filters[$count]->filter_namekey.'">'.$html[$count].'</div>';
				</div>
				<?php
			$count++;
So all the filters are stored in the $html array.
If you want to display a specific filter only you can do like that:
foreach($html as $h){
if(strpos($h,'AltureElevacion')) echo $h;
