Finding and sorting products
11 years 7 months ago #99843
Hello, I would like to know how I can configure the Joomla search to search between products and categories of HikaShop.
I also want to know if is possible to add a module to select various product management criteria. For example to see them sorted by price, by name, availabilities, etc..
Finally wanted to know if there is way to see the list of all products from the backend of HikaShop, choosing instead to go category by category to view.
Thank you very much.
Last edit: 11 years 7 months ago by Ronon.
11 years 7 months ago #99924
1. You just have to use a joomla search module, then enable the search products & search categories hikashop plugins.
2. For that, you have to use the filters. www.hikashop.com/fr/support/documentatio...-filter-listing.html
3. In the backend listing, there is filters, just select "all sub elements" for the latest filter and it will display all the products.
