Product picture to big
13 years 2 months ago #110383
I have a problem with the picture size. I changed the width of the picture to 300px and now it cuts the text on the right side.
How can I change the size of the thumb picture without influencing the other text?
Thank you for your help
  • Thank you received: 14210
13 years 2 months ago #110393
That's because the left and right parts are limited to 50% of the width each. So if the image is bigger than 50% it goes over the right area as you can see.
So either keep a smaller image on the product page, or increase the left area share size to 70% for example.
You could do that by changing:
.hikashop_product_left_part {
text-align: center;
float: left;
width: 50%;
and:
.hikashop_product_right_part {
border-left: 1px solid #DDD;
float: left;
padding: 10px;
margin-bottom: 30px;
in the frontend CSS file of HikaShop that you can edit via the Display tab of the configuration.
The following user(s) said Thank You: DocSnyder
