Problem with HikaShop Business license
11 years 7 months ago #120681
-- url of the page with the problem -- : www.tengoqueprobarlo.com
-- HikaShop version -- : 2.2.0
-- Joomla version -- : 2.5.11
-- PHP version -- : 5.2.17
Hello, in the Joomla update manager, I get this error regarding HikaShop Business license: "We did not find a licence attached to your website". I am logged in Hikashop.com and can not find how to specify the URL of the site where I have installed HikaShop Business. Can you help me? Thank you.
11 years 7 months ago #120686
Hello, I've installed manually from a FTP directory without problems ... The only thing that happens now is that during the checkout to buy a product, I get this error, but the checkout does well until the end ...
Warning: in_array() [function.in-array]: Wrong datatype for second argument in /homez.714/tengoque/www/components/com_hikashop/controllers/checkout.php on line 770
Thanks ;)
  • Thank you received: 13538
11 years 7 months ago #120700
It's probably just a user session issue. logout/login from your frontend and try again and that should hopefully remove the warning.
11 years 7 months ago #121588
Hi, it seems that this is not the problem because the line keeps coming even without one is logged in the frontend (I have disabled user registration, purchase without registering in the store). Thank you.
11 years 7 months ago #121593
I think that you'll probably find a solution through this thread :
Regarding the warning message you can maybe replace your "YourWebsite\components\com_hikashop\controllers\checkout.php" file by the following...
Last edit: 11 years 7 months ago by Mohamed Thelji.
11 years 7 months ago #121706
Hey, it worked perfectly, no longer get the error. Thank you very much!
