i have a problem my cart comdule have a grong layo
11 years 6 months ago #127580
-- url of the page with the problem -- : proteinasbarcelona.es
-- HikaShop version -- : 2.2.2. hikshop busines
-- Joomla version -- :3.0
-- PHP version -- : x.x.x
-- Browser(s) name and version -- : crhome
HI i have this problem, the cart module on my web is too simple, i buy the hikashop styless to puu it like the pictures
but on my site mi cart module look like this why
how i can fix this , mi cart module looks so simply ogly can you help me to put it like the demo picture os the style RED
thanks.
  • Thank you received: 4035
11 years 6 months ago #127592
You configure the "mini cart" so it is displayed as it.
Just edit the HikaShop cart module in order to not display as "mini".
11 years 6 months ago #127661
thanks but i have the same problem in the item layout as you can see here
the item cuantity its so big and sees ogly too,
how can I made this white frame adaptable o auto .
thanks
i wanna see it like this
sorry for my english
  • Thank you received: 13538
11 years 6 months ago #127716
That's because of your joomla template which forces the size of the input fields to be bigger.
If you don't want that, you should remove the code:
media="screen"
input[type="text"], input[type="password"], input[type="email"], input[type="url"], textarea {
width: auto;
padding: 8px 0;
color: #791202 !important;
font-size: 12px;
font-family: 'Century Gothic', Arial, 'Arial Unicode MS', Helvetica, Sans-Serif;
font-weight: bold;
font-style: normal;
text-transform: uppercase;
text-shadow: none;
from your template CSS file proteinasbarcelona.es/templates/plantill...nes/css/template.css
The following user(s) said Thank You: redconect
11 years 6 months ago #128142
solved thanks
