Problem with the cart Print
11 years 2 months ago #143261
-- url of the page with the problem -- : www.gaststaette-stadt-bergen.de/catering-partyservice-1.html
-- HikaShop version Business-- : 2.2.3.
-- Joomla version -- : 3.2.2
-- PHP version -- : 5.3.28
-- Browser(s) name and version -- : Firefox 26
Hallo,
When you print out the shopping cart links appear. When printing from demo.hikashop.com everything is ok. Where do you enable change, I do not come on.
Sorry my English, Google Translator.
Best Regards
Bernd
Last edit: 11 years 2 months ago by larryleise.
  • Thank you received: 13536
11 years 2 months ago #143352
It seems to be coming from the CSS of your template. Can you try to switch to a default template of Joomla and see if you still have the problem ? If not, then please contact your template provider so that he can provide a precise solution on that.
11 years 2 months ago #143666
I have installed on a test page HikaShop. bahnhofstrasse32.de The result has not changed. I only use:
Joomla 3.2.2.
HikaShop
Protostar - Joomla Template
(Compatible HikaShop) Even with the template Glass of JSN it does not work.
Please, please help me.
Best Regards
11 years 2 months ago #143717
I have again installed everything. Now with Joomla 2.5.8. and everything is wonderful. Could the fault of Joomla 3.x lie?
Best Regards
Bernd
  • Thank you received: 403
11 years 2 months ago #143896
The issue might indeed comes from Joomla 3.x.
Did you experienced this anywhere else on the website or with any component?
11 years 2 months ago #143917
with the printer function of the browser, I see the URL on other websites, for some elements. So the fault is likely to Joomla 3.x.
With the IE11 does not work for me the Cart Print. Neither with Joomla 3.x / 2.5. Firefox and Safari are ok with Joomla 2.5.8.
Now I'm at a loss.
Best Regards
Bernd
11 years 2 months ago #144101
It's not a problem of Joomla 3.x but with the templates of Joomla 3.x which always add links like that on the printed version of the pages. We published a new build of the latest version of HikaShop which has additional CSS in order to avoid that.
You will have to download HikaShop again on our website and install it again on your website in order to get the fix. If you had customized the frontend CSS of HikaShop, you'll have to add that line in your frontend CSS:
@media print { .hikashop_no_print:after { content: "" !important; } }
Time to create page: 0.112 seconds
