Download Products with a required contactorm
10 years 11 months ago #153512
Hi!
I'm not sure if it is here yet, or it can be done with the default HikaShop but i would like the Digital Downloads only to be available, after people filled in a contactform.
So i know who downloaded it, and can used that information later on.
Is this possible within HikaShop or should i use a 3rd party extension?
Regards!
10 years 11 months ago #153521
This is possible in HikaShop.
When installing, in the Wizard options select that you want to sell virtual products, that will set default configurations for that.
Then create product with files attached, then the customer must buy the product and his informations are asked in the checkout, the complete address etc.
10 years 11 months ago #153611
Hi Xavier,
Thank you for your reponse.
However, what if i already installed HikaShop?
Can't found this option now.
  • Thank you received: 13536
10 years 11 months ago #153623
In that case, just make sure that the "force shipping regardless of weight" option is turned off in your HikaShop configuration.
