Auto-fee for every vendor and products
  • Thank you received: 13
13 years 10 months ago #75963
How can I assign automatically the a fee (example 25%) for every vendor without setting it for everyone?
Can I set it in the main options of Hikamarket?
Also, if I have a certain default fee for the vendor, if I chose to assign a different fee to his product which fee will be used? Vendor fee or product fee?
  • Thank you received: 4078
13 years 10 months ago #75967
You can configure default fees in the first tab of the configuration panel.
demo.hikashop.com/administrator/index.ph...kamarket&ctrl=config
Fees priorities are:
- Product fee
- Vendor fee
- Default fee
The quantity option does not impact the priority.
So if there is a vendor rule with quantity 2 and there is no rule for the product with quantity 2, the rule of the product with quantity 1 would be use.
But the currency could impact the priority.
So if for a product there is no rule for the currency "Euro €" (but one with for the currency "Dollar $"), it would check the vendor rules.
