Setting vendor's products can not add into cart
10 years 3 months ago #165857
-- HikaMarket version -- : 1.4.1
-- Joomla version -- : 3.2
-- PHP version -- : 5.3.13
Hi, my website need set some vendor can not sell their products,
that means, customer should not add their products to cart, only check information of their product.
How to get it, thanks for your help.
  • Thank you received: 4028
10 years 3 months ago #165862
I think the best is to use a "product template" where the "product quantity" will be set to zero.
If you don't give the right to the vendors to change the product quantity (you remove the ACL product/edit/quantity) the product won't be available for customers (not possible to add a product in the cart if it does not have any stock).
The following user(s) said Thank You: liuchenbo
10 years 3 months ago #165902
Yes, that's a good idea.
Thanks a lot and there is a little problem,
may i replace "No stock" to " "(blank space) ,
because it looks stranger for some special products.
10 years 3 months ago #165903
Sure. It is an HikaShop translation, so you can use a translation override.
Time to create page: 0.037 seconds
