Use product approvals to yes but products published
  • Thank you received: 11
5 years 2 months ago #310399
Hi!
1.I m trying to create a multivendor eshop. (everyting is uptodate).
Use product approvals is set to yes. But products are published without approval. I m sending screenshots.
2. My shop will be for services and products. Is it possible to have other template for products and other for services? I thought if it can be done by choossing the category. For example if the frondend vendor-user adds a product to the category services hikamarket loads the template for services...
Last edit: 5 years 2 months ago by Jerome. Reason: Removing PDF screenshots
  • Thank you received: 4028
5 years 2 months ago #310402
For your screenshots, please use jpeg or png files, not pdf.
Thank you for your understanding.
1- if your vendor have the approval ACL his products will be automaticallly approved.
2- yes. That's something done and related to HikaShop (and not HikaMarket)
5 years 2 months ago #310479
Ok for 1. we re good. Thanks
For 2 can you be more descriptive please?
How hikashop? I need this to be done from the front
5 years 2 months ago #310488
You should create a new topic, in the HikaShop section of the forum, for that part.
As I wrote juste before, HikaShop do manage the product template feature. So it's an HikaShop question, not an HikaMarket one.
