Products not displaying.
13 years 8 months ago #11976
I am not sure what I did, but none of the products I am adding are showing up on the front end at all.
I created categories and sub categories and started adding products. I have double checked that everything is published, and that everything is filled out for the products, but no luck.
Very confused, and worried!
Our page is currently locked, so I will need to send a U/P if you need to see it. Hopefully I am just missing something obvious.
airdriesigns.com
Thanks in advance!
  • Thank you received: 13372
13 years 8 months ago #11979
Please go in the menu Display->Content menus and edit the options of your menu. There, check on the option "associated modules". Do you have something published in it ? If yes, unpublish it. Then, save the options. That will display an error message to automatically recreate the associated module with the correct options (that's the associated module which is in charge of displaying the products for categories listings).
13 years 8 months ago #11981
There is nothing published in the Associated Modules. I tried to enable, then disable, saving in between, but no luck.
Even after changing them, I did not get any error messages.
13 years 8 months ago #11986
What if you create a new menu of the type category listing, do you get the products ? Normally, the associated module of e new menu should be created automatically when displaying the new menu...
If you go in the menu Display->Content modules, do you have modules with the title "Associated products listing for category listing menu X" ? That's the onces created automatically normally. If you don't, then you need to create a new module for products and then use it as an associated modules in your menu.
