Have too many related products showing
13 years 5 months ago #19415
I've added 3 related products to one product but it seems to be showing all my products underneath.
I've attached the display section.
Any ideas?
  • Thank you received: 13376
13 years 5 months ago #19422
That's a screenshot of your configuration.
Each menu and each module has its own display configuration that you can access via the menu Display->content menus/modules. So you should look there for your related products module in order to set its options properly.
13 years 4 months ago #20564
I'm not understanding.
I went to modules and they're all disabled. I have 3 related products for 5 of my products, but it shows all my products.
See image if that helps. I'm not too sure what to do to only show the products I added in related products.
13 years 4 months ago #20566
You need to edit the options of the module you added in the option "modules under the product page" of the configuration of hikashop.
13 years 4 months ago #20573
Thanks for the quick reply,
I tried that before, they're all set to not be published, that's why I'm confused.
:blink:
13 years 4 months ago #20575
Are you sure that you're editing the option "modules under the product page" and not the option "modules to display under the main area" ?
13 years 4 months ago #20577
i was using the wrong section, but I went to "Modules under the product page" and if I turn them all off nothing shows and then I turn one associated product on and all products show in the related products, so basically it's the same issue.
13 years 4 months ago #20579
Of course, you need to configure correctly the module that you're publishing in that option so that it shows only the related products of the current product.
13 years 4 months ago #20584
Ahh, got it, finally.
Thanks a bunch, perfectly clear now!! :)
Thanks a ton
:woohoo:
