Advice users if "Maximum quantity per order" = 2
13 years 9 months ago #20858
Hi!
We've set the "Maximum quantity per order" for all our products for 1. But if a user tries to add the same product another time to the cart he get's the message "Product successfully added to the cart". Is there a possibility to advice the user, that this product is already in his cart?
Best regards
  • Thank you received: 13533
13 years 9 months ago #20869
It's not easy to do. That's why it's like that :)
We'll see what we can do for next release.
13 years 8 months ago #22446
Has something changed/improved concerning this problem in the new version 1.5.3?
13 years 8 months ago #22449
Yes, you should have a message saying that the quantity limit has been reached.
13 years 8 months ago #23055
I just updated to 1.5.3 but I don't see this message. When and where should this message appear?
13 years 8 months ago #23061
You should turn off the ajax add to cart option in the checkout tab of the configuration. The message should appear on the page after adding a product to the cart.
13 years 8 months ago #23132
Nothing has changed after I turned off the ajax add to cart option!
13 years 8 months ago #23157
I just tried again on our end and turning off the option "Use AJAX when possible for add to cart buttons" solves the problem.
The only other thing I can think of it that you edited the file show of the view product before updating and thus you don't have the modification of that view in order to handle that option which is just ignored. Please check on that.
13 years 8 months ago #23214
I deleted the customized view "show", now I see the warning message.
Why isn't it possible, that this message appears in the pop up window?
13 years 8 months ago #23234
It's not that it's not possible. That's just the way we did it.
13 years 8 months ago #23324
Then let's rephrase this: it would be nice to use the pop-up window AND see this warning message ;)
13 years 8 months ago #23372
We'll put that on the todo list but it's not really a priority for now.
  • Thank you received: 5
6 years 7 months ago #297445
Hello, following this topic, it is possible to make a warning when the user tries to add a product when the car is already full.
Thank you very much Nicolas
6 years 7 months ago #297484
If you have the "add to cart legacy" setting turned off and the HikaShop cart notify plugin enabled, then you should get the exact error message when a product couldn't be added to the cart for some reason.
6 years 7 months ago #297497
Hi thanks.
Now the warning comes out correctly, but instead I can not redirect the car, once the product has been added.
Thank you
6 years 7 months ago #297518
Ah yes, with the plugin activated, then there is no automatic redirect to the checkout.
There is no way to have both right now. But that's a good idea.
We'll add an option to the cart notification plugin so that you can have both with the next release of HikaShop.
