Products not showing after successful upload
13 years 7 months ago #21331
I've uploaded products via the csv import option. No errors where thrown and it said the upload was successful. However, when I go into the Products section of Hikashop, nothing is showing up. Did I miss a step for uploading the products? Do I need to turn something on?
  • Thank you received: 13490
13 years 7 months ago #21340
Did you put your products in categories ? If so, did you go to the category where they are ?
If it said it imported it, your products must be there.
Maybe you applied some filters on the products listing ?
Could you do a screenshot ? And maybe give the first few lines of your CSV ?
13 years 7 months ago #21348
Thank you for the reply! I've actually figured out that I've uploaded variants. I've started another thread above this one dealing with the issue. I will post my cvs lines there.
Thanks!!
