Problem with shipping/billing address fields
15 years 7 months ago #8550
You can easily have both shipping and billing addresses selection always displayed by editing the file address of the view checkout and removing the code:
if($this->shipping_address==$this->billing_address){
$checked = 'checked="checked" ';
$style = ' style="display:none"';
You can also remove the two lines below to remove the checkbox:
<input class="hikashop_checkout_shipping_same_address" <?php echo $checked; ?>type="checkbox" id="same_address" name="same_address" class="inputbox" value="yes" alt="Same address" onclick="return hikashopSameAddress(this.checked);" />
<label for="same_address"><?php echo JText::_('SAME_AS_BILLING');?></label>
Concerning the address step, what is your workflow ? Could you give a link to your shop so that we can have a look ?
15 years 7 months ago #8589
Thank you very much, address selection works.
My workflow is:
cart_coupon,login,address,shipping,payment,confirm_cart_coupon_status_fields,end
The site is
www.accessibleottawa.ca/leaves
(don't be afraid, it's just my sandbox)
Thank you,
15 years 7 months ago #8591
I was able to go to the shipping method selection view and I got the message "No shipping methods available to your location". Probably because the country I put in the address isn't in the zone that you set in your shipping methods. So it goes after the address selection on my end.
15 years 7 months ago #8597
I changed a shipping method to USA (for your zone), but the problem was in choosing shipping adr different from billing one. I'm receiving screen with the addresses twice (I have to confirm addresses twice), and after that I'm transferred to shipping methods.
15 years 7 months ago #8598
Correction. It happens only if I clicked radio buttons. Please try to swap addresses
15 years 7 months ago #8610
Could you try the fix on that post: www.hikashop.com/en/support/forum/3-bug-...-not-added.html#8211
That might solve the problem.
15 years 6 months ago #8693
Hi, It didn't help, but probably will not be big problem. Thank you again
