URGENT - No payment method found! Need Help ASAP!
13 years 4 weeks ago #28529
So I have a new hikashop store setup and everything is working but when I get to the checkout it has a blue bar at the top that says no payment method found. I enabled the Check payment plugin. Why is it saying this?
I need this solved asap as I am trying to put an international site online and can't do it until I know the store it working!
Thank you!
  • Thank you received: 13378
13 years 4 weeks ago #28530
It's a common error which happen when you don't configure the payment method correctly. You can follow the FAQ on www.hikashop.com/en/support/documentatio...ins-listing.html#faq to solve the problem.
13 years 4 weeks ago #28532
The payment method is properly configured, it is the check payment, i turned it on and the plugin is enabled. I have a shipping method enabled as well and that is properly configured. The store is on and when I turn on joomla debug i see no errors. I also have USD currency so that works too.
The FAQ did not help and I really need this working.
13 years 4 weeks ago #28533
Then please do a screenshot of the payment method configuration and give the URL of your shop so that we can see the problem.
13 years 4 weeks ago #28536
Sent the info to you via PM. Let me know if there is anything else you need.
13 years 4 weeks ago #28537
You didn't give the URL of your website so I can't check it out.
13 years 4 weeks ago #28538
PMed it to you just now. Haha I am freaking out and forget to add it.
13 years 4 weeks ago #28540
It's working fine...
13 years 4 weeks ago #28546
Thank you so much! What did you do to fix it? Yes, now it works fine. Thank you hikashop! You guys really do have a great store.
13 years 4 weeks ago #28547
I did not do anything. I just checked your settings and then tried to place an order and it worked.
13 years 4 weeks ago #28548
Really? Hmm is it possible that hikashop has some sort of caching system that maybe by the time you logged in it had updated and the products were working?
13 years 4 weeks ago #28550
Not in HikaShop but there is a caching system in joomla.
Anyway, if it works then it's all good.
13 years 4 weeks ago #28552
Yes thank you! I will be sure to use this with my other clients as I really feel this is the best shopping cart system out there right now for joomla.
