Installation problem
13 years 1 week ago #30730
Congratulations for this great component that I'll buy since my site will be validated by my client.
But now, I'm driving crazy with the installation on my ISP site...
I've installed your component on a few local sites without any problem.
Now I'm getting the following errors :
JFolder: :files: Path is not a folder. Path: /var/www/---/httpdocs/tmp/install_4ecc2493aafdb
JFolder: :folder: Path is not a folder. Path: /var/www/---/httpdocs/tmp/install_4ecc2493aafdb
JInstaller: :Install: Cannot find Joomla XML setup file
I made a chmod -R 777 httpdocs on the whole site and Hikashop doesn't install !
BUT others component like Akeeba DO !!!
Because all directories are writable, could you put me on the way to understand the problem ?
Thanks by advance.
Joomla 1.7.2 with Directory Permissions Writables especially /tmp
Last edit: 13 years 1 week ago by codewarrior. Reason: Precision added
  • Thank you received: 13379
13 years 1 week ago #30754
You should try an install via FTP as explained there:
www.hikashop.com/en/support/documentatio...-install.html#errors
That should help the install process on that problem.
13 years 6 days ago #30816
Strange to do it that way ???
for information, the hikashop.zip was copied in /tmp
I just :
- unzipped it under Unix
- then tried Joomla Install from Directory -> same error.
I had to :
- chmod files and directories to 666 and 777 for having installation working
- clean /tmp directory
- do again chmod
It's quite a constrainst for an install and updates for your great component
May I remind you that Joomla updates and other components are installing well in my environment.
Could it be something specific in your installer ?
Thanks for help
13 years 6 days ago #30837
We are able to install the package directly via the installer without any problems on our end. It must come from your server settings and the fact that the HikaShop package contains a lot of files compared to other extensions which means that the install process is a lot more resources hungry.
13 years 5 days ago #30880
If this can help for improvements, I've got the same installation problem with JCE and last Joomla 1.7 updates.
With regular installation, it hangs with .zip packages, but worked with .tar.gz packages
It's like if the Joomla unzip is having a writing problem.
Maybe you could provide a .tar.gz package of Hikashop ?
13 years 5 days ago #30922
I don't think that it would be a definitive solution or even that it would change anything.
Do you see a difference on your end if you try to install with a tar.gz instead of a zip ?
You can easily convert your hikashop install package to a tar.gz with 7zip: www.7-zip.org/
12 years 11 months ago #31772
I had the same problem. On one server the components installed without issues form the zip package, on another server it wouldn't install with the mentioned error meessages.
I repacked the intall package into .tar and it worked.
Thought I'd post it here, so others having this problem find a solution.
12 years 10 months ago #35556
If this can help too, I made the manip to upgrade to 1.5.5 version.
I repacked the .zip in .tar, with 7zip and it worked like a charm !
It's simpler than FTP solution.
Strange problem ! Obviously not a permission problem on servers.
12 years 10 months ago #35584
Thank you for the feedback.
Then this one must be an issue between the Joomla zip extraction library and the server settings.
We'll add that possibility to our documentation.
