Products not showing
15 years 9 months ago #3610 by panosa73
Ok, I don't know what I'm doing wrong because it's pretty simple. Create a category, then create a product under that category. But when on the front end, none of the products show. The categories are there, you click on one, and then nothing, nothing's there. On the back end, if you go to Products and click on the category, they're there.
I checked the demo and all the settings are the same as mine. What's the problem, any ideas?
Thanks you.
Here's the test site.
www.webdevloft.com/longbow/index.php?opt...ut=listing&Itemid=56
Thank you.
15 years 9 months ago #3615 by nicolas
Replied by nicolas on topic Re: Products not showing
You probably didn't add an associated module to your menu. Go to Display->Content menus and edit your menu options. There, save the options. You should get a message telling you that you're missing an associated module and it will let you create it in one click. For further details, we have a documentation which explains display of content on the front end:
www.hikashop.com/en/support/documentatio...splay-front-end.html
Time to create page: 0.152 seconds
