Products Not Found
12 years 10 months ago #36296
I have imported 5240 product records and receive a message that the import was successful and 5240 product records were added.
"product_code","categories","product_name","product_weight","price_value","product_published"
"300.N.CC","Name Metal Plates","300 Name (ONLY) Chrome on Chrome Plate","1","19.93","Yes"
My guess is it wants something other than "Yes" for the field "product_published"
Doug
  • Thank you received: 13379
12 years 10 months ago #36331
Yes. It should be 1 and not Yes.
12 years 10 months ago #36335
I changed it to "1", but I still have the same problem.
12 years 10 months ago #36336
Do you see the products in the back end ? Could you give a link to your products listing on your front end ?
12 years 10 months ago #36339
No. The products are not seen in the backend.
yourcarthings.com
You can see the products in the front end by doing a search. For, example, search for "Honda". If you select the product categories and then click on a category, no products for that category will be displayed.
12 years 10 months ago #36369
Did you configure a category listing menu in the menu option of the hikashop categories search plugin ? If not, you should do it.
Then, if you don't see the products, neither on the front nor on the back end, it means that they weren't added by the import. Could you try again to import them ?
12 years 10 months ago #36372
The menu item type is "Categories Listing".
The products can be seen on the frontend by doing a search; such as "Honda"
12 years 10 months ago #36421
I just "unistalled" HikaShop, reinstalled it, and then imported the products again. I also manually added a product. Neither one of these allowed me to get a display of the products in the backend.
Very strange.
Doug
12 years 10 months ago #36453
Could you provide a back end access so that we can see that ?
12 years 10 months ago #36459
Login: ******
Password: ********
Last edit: 12 years 10 months ago by nicolas.
12 years 10 months ago #36468
Cela ne fonctionne pas.
Veuillez nous fournir un compte valide via notre formulaire de contact plutot que sur le forum pour plus de sécurité.
12 years 10 months ago #36469
Huh?
12 years 10 months ago #36508
Sorry, it was late :)
The account does not work. Please provide a valid access via our contact (for more security).
12 years 10 months ago #36572
All your products have a quantity of 0. So that means that they have no stock.
And in the Display tab of the configuration, you set the option "Display out of stock products" to No.
So that's why you don't see your products on the front end. If you turn on the option you will see them.
