Upgrade to Essential Broke my Body Class
13 years 2 months ago #39569
Hi Guys,
Hopefully you can help. I upgraded my site last night to Essential version and its broken my CSS. The online store link is fine body class="store" then I see a catalogue of all my categories > Click a category still fine body class="store" but when I click a product under the category.... Shazaaaam - broken, body class="default"
How to fix it?
Believe in Better
  • Thank you received: 13533
13 years 2 months ago #39606
HikaShop does not change the body HTML tag of your website. So I don't see how the update of HikaShop would be related.
Could you post a link to your shop so that we can see your problem ?
13 years 2 months ago #39612
Sure here is a link: airsoftandtacticalgear.co.za
Go to online shop. See the categories . eg watches.... Click it see the items watch products. click one and see what happens in the URL and body class... the body class changes from "store" which is declared in the menu item (Online Store) and then on the product view changes to default....
Believe in Better
13 years 2 months ago #39685
Go in the menu Display->Content modules and edit the module with the id 28. There, make sure that the "menu" option is set to "online shop". Then the URL should be better and your template too.
The following user(s) said Thank You: nowherenowhere
13 years 2 months ago #39806
Awesome that sorted it :) Thank you I really love this extension - I'm building another eCommerce site with it now
Believe in Better
