Problem with Checkout process and custom fields
13 years 1 month ago #42611
I already bought the business version, but I was wondering if you can help me with some doubts that I have.
I've been testing the site and I have the following issue:
1. I put the first order without any kind of problem but if I want to do another checkout, the system gives an error.
In the Admin panel I modified the proccess in this way:
(I tried with or without these options and I got the same error)
. No registration
. No Login
Checkout workflow:
Cart (next)
Login / Address (next)
Fields* / Cart / Payment (next)
*Fields: I added few new fields and one of them, is (date of event). So when I do the "second checkout" the system shows me an error page with this title
(500 - DateTime::__construct() [datetime.--construct]: Failed to parse time string (03-30-2012) at position 0 (0): Unexpected character)
I think this happen because the system keep active all the info into the forms (cookies or something like that).
For that reason I need to do the logout and restart all the process.
Is there any way to clear ALL data from the forms once I complete the order?
Can I get a favor (of course if you have time).. could you check the site and do a checkout after you finish, please select another item and do again a checkout. Please!
store.xpressjumpers.com/
<<Will be better if you can check yourself because maybe with my English you can't understand me what I trying to explain>>
Thanks in advance,
Last edit: 13 years 1 month ago by caguilar.
  • Thank you received: 13545
13 years 1 month ago #42760
I don't know where that error comes from but cleaning the fields after the order is a good idea.
That can be done quite easily by adding the code:
$app->setUserState( HIKASHOP_COMPONENT.'.checkout_fields_ok',0);
$app->setUserState( HIKASHOP_COMPONENT.'.checkout_fields',null);
after the code:
$app->setUserState( HIKASHOP_COMPONENT.'.coupon_code','' );
			$app->setUserState( HIKASHOP_COMPONENT.'.cc_number','');
			$app->setUserState( HIKASHOP_COMPONENT.'.cc_month','');
			$app->setUserState( HIKASHOP_COMPONENT.'.cc_year','');
			$app->setUserState( HIKASHOP_COMPONENT.'.cc_CCV','');
			$app->setUserState( HIKASHOP_COMPONENT.'.cc_owner','');
			$app->setUserState( HIKASHOP_COMPONENT.'.cc_valid',0);
			$app->setUserState( HIKASHOP_COMPONENT.'.checkout_terms', 0 );
in the file components/com_hikashop/controllers/checkout.php
That should hopefully fix your problem.
13 years 1 month ago #42764
Awesome!!! :woohoo:
I really appreciate it!
That was the solution, now its working fine! both problems where solved (finish button and the cache)
Thanks again, Nicolas!
