Need some help with layout
15 years 9 months ago #4843 by Toolcrazy
I need to do two things.
First, I need to move the shipping address box below the billing address box on the checkout page. I found the view pages, but I don't know enough about PHP to figure it out.
Second, I need to modify the order of the addresses popup. I need;
Name
Address
City
State
Zip
I know the current setup is for Europe, but I need to format it for the US. I found the address template and have modified it to the way I want. But I need to change the forms, now.
Also, Can I remove the background from the address popups?
15 years 9 months ago #4863 by nicolas
You don't need to modify the views for all that.
For the shipping address box, you can just edit the HikaShop CSS via the configuration in the tab display and remove the line float:left; from the code
.hikashop_checkout_address_right_part { width: 350px; float: left; }
Don't forget to save the configuration once you did the modification and then clear your browser cache.
The address fields can be edited via the menu Display->Custom fields. You will be able to reorder them there as well.
The background of the popup is added by your template, you should tweak your template CSS for that.
15 years 9 months ago #4890 by Toolcrazy
Thanks very much for the help. Everything worked as suggested. I was just making things harder than it needed to be.
Time to create page: 0.221 seconds
