Continue to Products not displaying in categories.
15 years 10 months ago #5495 by JWeb5
I tried the reinstall but I still have no luck.
I may have misspoke earlier today also.
In =Hika_products i have 1061 same as my csv
In =Hika_category_products I have 869. So the missing products are not getting into the category_products in the db's table.
Any new thoughts?
Thanks,and sorry for all the troubles.
15 years 10 months ago #5499 by nicolas
Which version of hikashop are you using ?
For the products missing, does the categories exist ?
From what you're saying, I understand that the 869 products are in there and that you can access them right ? So, the best would be to find one product which doesn't and try to understand why it wasn't linked to a category. Maybe you could copy its CSV line here so that we could better see the problem.
15 years 10 months ago #5501 by JWeb5
the free version(essential?)
The categories exist, one of them has products that are displaying, but were maunally added. The upc column(D) with a letter eg 205a are shown front and back. The numerical are not added to the db _category_Products. There are multiple other products in different categories thatare not being shown,but these few are whats so puzzling to me. Half in,Half out????
French Angel 199.99 17 205026 1 lb
Grey Angel 85.79 17 205034 1 lb
Asfur Angels 179.99 17 205036 1 lb
Rock Beauty 49.99 17 205040 1 lb
Koran Angel 179 17 205042 1 lb
Maculosus 149.99 17 205057 1 lb
Nox 33.59 17 205535 1 lb
Yellowfin Nox 72.99 17 205a 1 lb
Blue 68 17 205b 1 lb
Blue Fin Damsel 8.99 17 205c 1 lb
15 years 10 months ago #5503 by nicolas
Aren't you missing the commas/semicolons in there ?
15 years 10 months ago #5505 by JWeb5
I copied out of a spreadsheet Tab delimeted. When it's saved itgets saved as csv with ;," as the text field delimeters. Thats how all of the other products were uploaded also.
15 years 10 months ago #5508 by nicolas
Could you open the CSV with a text editor like notepad++ and copy those same lines here ? It's just to check that the format is good.
Also, if you could copy along the header of the file (the first line).
15 years 10 months ago #5511 by JWeb5
ive got $ formating in all numeric cells , lol? who knew. I'll take itout and see whst it does.
15 years 10 months ago #5518 by JWeb5
still no luck. unless i am completely formatting the csv and its delimeters wrong,im still stumped.
15 years 10 months ago #5519 by nicolas
Could you copy some lines of the CSV here (the lines in your text editor, not in excel) ?
15 years 10 months ago #5521 by JWeb5
"product_name";"price_value";"categories";"product_code";"product_weight";"product_weight_unit "
"Bicolor";17.99;21;215001;1;"lb"
"Red Lip";19.99;21;215004;1;"lb"
"Horned";26.49;21;215005;1;"lb"
"Midas";37.89;21;215006;1;"lb"
"Smith's";26;21;215010;1;"lb"
"Barnacle";52;21;215011;1;"lb"
these are showing front and back.
"Blue Ribbon";99.99;25;235012;1;"lb"
"BandedSnake";37.99;25;235020;1;"lb"
"Garden";25.99;25;235024;1;"lb"
"Golden Dwarf";249.99;25;235045;1;"lb"
"Flaming Prawn Goby";51.99;26;230001;1;"lb"
"Bi Color";4.99;17;205001;1;"lb"
"Bi Color";34;17;205002;1;"lb"
The last set are some of the ones that aren't showing. Every line was initially added via the same csv? I dont know why it would dropcertain categories.I've triple checked the categorie links....
15 years 10 months ago #5524 by JWeb5
Fixed,I dropped both tables again, and a reinstall. I tend to over complicate things,????
Thanks for the help!
15 years 10 months ago #5529 by nicolas
I see that the categories of both sets of products are not the same. Maybe the category id wasn't the correct one, or the type of the category wasn't the correct one (the category type needs to be "product" in the database. If that's not the case, as it could happen in some strange cases, then the categories might not show up as well as the products attached to them).
