I'm trying to attach a downloadable PDF to each product in my store. The PDF is a printable information booklet and the booklet is the same for each product.
When I attach the booklet using the "Files - Add" area in the product setup, I can browse to the location of the file on my hard drive and it uploads the PDF to the server into my upload files directory. However it seems to make a copy of the PDF and renames it with a unique name. So with 20 products in my store I now have 20 versions of the PDF on my server. If I try to edit the attached file name I get the same upload from my hard drive process.
How can I attach the SAME instance of the file to each product? I think there needs to be the ability to select a file that is already present in the uploaded files directory.
In the meantime the only way I can see how to edit the file pointer is via PHPmyadmin. Is there another way?
cheers!
