Urgent Problem with Coupons
  • Thank you received: 24
12 years 5 months ago #66273
If i create a discount coupon and select all the products and 10 percent discount it has some errors to some baskets it adds a 20 % instead a 10 % and in others its allright any help ?. I observed the products that doubles are the oldest, the newest has not that problem, could it be and actuallization error?
Another thing is that if a client makes an order and cant pay it can he recover the order and try to pay again or has to repeat all the process again?
Last edit: 12 years 5 months ago by condorazul.
  • Thank you received: 13492
12 years 5 months ago #66295
You should try that fix:
www.hikashop.com/en/forum/3-bug-report/6...culations.html#66270
It has solved the problem on our end.
He sure can pay the order later. Via his user control panel, he can see his orders and if you activated the option "Payment of orders not paid immediately" of the configuration, he will see a "pay now" button for unconfirmed orders.
12 years 5 months ago #66326
Does not solve the problem in mine.
www.lacestamagica.com
choose the baby basket cost 30 €
add coupon PROMO5
it should discount 5%
it discounts 10 %
Basket before actualization makes 10%
baskets after actualization makes 5% wich is correct
  • Thank you received: 403
12 years 5 months ago #66600
Hi there,
You should try with this file since the other one I posted was not including the fix.
It should solve your problem :)
File Attachment:
File Name: currency_2...21-2.zip
File Size:13 KB
12 years 5 months ago #66706
Not Solved Same Issue
try what i wrote before
currency.php changed, same problem
12 years 5 months ago #67003
Please provide a backend and FTP access to eliot via pm and he'll look at that tomorrow.
12 years 5 months ago #69458
Any news?
12 years 4 months ago #70681
Sorry for the long time I took to answer.
I just didn't gave you the irght file, we edited the discount.php in addition to the currency.php
I fixed it on your site. For everyone who want the fixed file, here it is:
File Attachment:
File Name: discount.zip
File Size:4 KB
