Default unit price for multi variant product
14 years 5 months ago #675
Is there a way to ensure the default product price (for a Product that has say, 3 prices to choose from depending on the Size selected—in a pull-down) is the lowest priced item?
I have my variants in the correct order, I have specified we are to display lowest price first, but in these instances, I get a random price showing up as the default.
  • Thank you received: 13533
14 years 5 months ago #687
Normally, the system will choose the default variant based on the default values for each characteristic of the product unless the variant doesn't exists. In which case, it will be random. It's not the behavior you're observing ?
If so, could you give us access to your website (the url where the problem is, an admin access to check the product information and an FTP access to fix the files which need to be fixed) so that we can fix the problem ?
Time to create page: 0.036 seconds
