Product display problem
13 years 9 months ago #6832
The site i'm working is having a problem...
www.astburygreen.co.uk/index.php?option=...ut=listing&Itemid=65
For the moment there are 6 products in the originals section, I want them all on one page, but for some reason it wont show more than five products. Ive changed columns, ive changed number of items - nothing seems to change the fact that it wont allow more than five items on the display. Where am I going wrong here?!!!
  • Thank you received: 13372
13 years 9 months ago #6833
I see 6 products on your link :)
13 years 9 months ago #6834
Do you see 6 products on one page? or 5 on the first page and the other image on a page 2?
13 years 9 months ago #6835
6 products on one page.
13 years 9 months ago #6836
Ok, i think ive seen the problem. when the page first lands its ok, but if in the drop down menu you select 'all' it just shows the first 5?!!!
Any reason?
13 years 9 months ago #6837
Indeed. No reason anymore.
You can edit the file components/com_hikashop/views/product/view.html.php and remove the code:
if(empty($pageInfo->limit->value)){
$pageInfo->limit->value=5;
13 years 9 months ago #8539
Oh no, Ive just found this thread, and removed the code in view.html.php as per your message but its still displaying 5 products only. Any ideas please?
Last edit: 13 years 9 months ago by natwith79. Reason: fixed php
13 years 9 months ago #8559
Could you do a screenshot so that we can see the problem ? If you use the latest version of HikaShop, you should not have to do this modification as it's already fixed.
