Options for products in Categories
12 years 4 weeks ago #73374
Could U help?
Is it possible to show list of options for each product on category page?
12 years 3 weeks ago #73561
  • Thank you received: 13378
12 years 3 weeks ago #73611
You can do that by creating custom fields of the table "item" via the menu Display->Custom fields in the Business edition and turning on the hikashop option "Display custom item fields" of your products listing.
12 years 3 weeks ago #73638
I am having a similar problem.
I created a custom product field. I included a graphic showing how I set it up
IN the "configuration/display/Default parameters for products box" I set Display custom item fields to yes.
It does not show in the product page " dev2.4mymerles.com/index.php/collars-leashes "
The custom field does not show
Brian
12 years 3 weeks ago #73759
Hi, Nikolas, brian662,
I wonna show U what I want.
I have options for product:
product page
{BLACK|WHITE} for example
I want to show those options for each product (if it defined for this product) on category page:
category page
Last edit: 12 years 3 weeks ago by dima.
12 years 3 weeks ago #74014
As I said, you can do that by creating custom fields of the table "item" via the menu Display->Custom fields.
The custom field that you created is of the table "product", not of the type "item". Delete it and create it properly and it will work.
The following user(s) said Thank You: brian662
12 years 3 weeks ago #74048
Great - the table 'item' was counter-intuitive to me, mais il marche, at juis suis tres content.
Brian
10 years 4 months ago #164351
Bonjour Nicolas,
Nous avons suivie la procédure et cela fonctionne mais nous voulons pas afficher les mêmes options a tous les produits
chaque produit a ses propres variantes et c'est les variantes que nous désirons afficher dans la page qui liste tous les produits d'une catégorie, afin d'éviter de cliquer sur : choissir une option
est ce possible?
merci
stéphan
10 years 4 months ago #164464
La solution sera probablement d'ajouter tous les produits devant contenir le champs personnalisé dans une catégorie, puis ajouter cette catégorie via l'option de restriction "catégorie" de la page de configuration de votre champs personnalisé
