Shop module not displaying any products
14 years 3 weeks ago #783
Shop module published in sidebar diplays list of the 4 categories I have - all OK there. However, click on category and no products are displayed.
I do have products in category and they are 'published'.
Have I missed a setting somewhere?
  • Thank you received: 13374
14 years 3 weeks ago #787
Yes. Please try to follow our tutorial explaining how to do it :
www.hikashop.com/support/documentation/6...ml#categories_module
That should help you sort it out. If you're still stuck please post more details like the options of the module and the menu options of the menu attached to the module.
14 years 3 weeks ago #811
Thank you - all sorted now. Went back and retraced my steps and started all over again and this time worked fine
13 years 6 months ago #16943
same problem, not solved so far.
Link to Testshop: Click
Maybe has something to do with missing "Associating modules".
Pls tell me which specific information you need to help me [alternatively Login via PM]
Thanks in advance.
Matt :unsure:
www.buch-comptoir.de
shop.buch-comptoir.de
[Weltweiter Versand seltener Bücher]
13 years 6 months ago #16944
Your problem is that the associated module to your menu is there but you set it of the type "category" and not "product". You can go in Display->Content modules, edit the module with the id 53 and change the type from "category" to "product" and that will greatly help :)
13 years 6 months ago #16945
Thx Nicolas, excellent help within minutes! Works great now. (Have some more layout questions, but will post them in the correct category). Thx again, M. :-)
