SPLIT Remove products and categories id in URLs ?
  • Thank you received: 315
10 years 7 months ago #150328
-- HikaShop version -- : 2.3
-- Joomla version -- : 3.2
-- PHP version -- : 5.3.17
-- Browser(s) name and version -- : Mozilla
The problem is that if I turn off ID for urls products with same name have the same URLS.
Is there any chance to split ID for categories and ID for products?
I wish to remove id for category but prtoducts need the ids.
How to do that?
I need it!
Я здесь добровольно!
10 years 7 months ago #150334
I support this topic, this problem must be solved.
10 years 7 months ago #150469
That can be made, the files to edit are "components/com_hikashop/router.php" and "components/com_hikashop/sef_ext.php"
It require good PHP knowledges.
10 years 7 months ago #150551
Do you plan to do it by yourself and inlclude in future version?
This is strongly need feature....
Also If I change this files - update of the hikashop will break this cahnges.
How could I overwrite they?
10 years 7 months ago #150562
It need inlclude in future version!
10 years 7 months ago #150614
The easiest way will be to rewrite them.
I add this feature on our TODO list but can't promise it for the next release. (lot of things to develop ;) )
But if you made the changes, we will be pleased to integrate them.
  • Thank you received: 13378
10 years 7 months ago #150859
There is no need for such future. For products with similar names, simply enter a different alias in them and the alias will be used instead of the name and it won't be a problem.
10 years 7 months ago #150894
Yes, there is no problem if I only one user of the shop. But how could I explain this for those whom I made this shop?
This is real problem. They don't care about it. But this is real problem if I plan SEO for it.
So I think about changing this files.
If you have no time I will try to do it by myself.
