product title too long for cart module
15 years 6 months ago #8735
I am using variants with pretty long characteristic values. My products are named like "product name + characteristic name".
That is fine in general, also in the checkout process.
But I have displayed a cart module in a sidebar, that has only limited width. Therefore when I add a product to the cart, there is not enough space and e.g. the price is cut. Therefore I would need the cart to display the short product name only without the full characteristic text.
I there a way to display the "name only" of a product in the cart module, but remain the full name in the checkout cart?
Thank you,
kohypon
15 years 6 months ago #8738
There is no option for that. However, you can go in the menu Display->Views and edit the file cart of the view product to change the display of the product name.
You could for example replace the code:
echo $row->product_name;
By:
echo substr($row->product_name,0,10).'...';
And that will display only the first 10 characters of the name followed by three dots.
15 years 6 months ago #8742
well that kind of solved it, but not very clean.
Maybe I should generally disable the product name to be added with the characteristic. I think I can remember, that there was a option for disabling the characteristic to be part of the product name. Unfortunately I cant find that option in Hikashop configuration.
Can you give me a hint, where this could be configured?
15 years 6 months ago #8743
In the config, under the tab display, you have the option "Append characteristics value to product name"
15 years 6 months ago #8744
I found the perfect solution for me. I added this function:
"function first_words($string, $num, $tail=' ...')
/** words into an array **/
$words = str_word_count($string, 2);
/*** get the first $num words ***/
$firstwords = array_slice( $words, 0, $num);
/** return words in a string **/
return implode(' ', $firstwords).$tail;
and made an echo like "echo first_words( $row->product_name, 2)"
This takes only the first two words (my product names itself allways contain two words) and kills the characteristics in the string.
Thank you,
kohypon
15 years 6 months ago #9677
Another solution which I used for this was to edit the cart module view (cart file of product view) and change out product_name for product_code, so the cart displays my short code and I also modified the cart file of the checkout view so the checkout displays code > product name > ....everything else.
