How do i move my products and categories?
13 years 9 months ago #8808
How do i move my products and categories from my hikashop site to another?
  • Thank you received: 13372
13 years 9 months ago #8816
You can go in your phpmyadmin and export the tables starting with jos_hikashop_ on your old website. Then, install hikashop on your new website, remove all the tables starting jos_hikashop_ and finally import in your new website's phpmyadmin the SQL file generated by the export of the old website.
13 years 9 months ago #8817
I did that and this is how it came out. www.soundrsa.com/ go to the products section
13 years 9 months ago #8820
I can't access your website. Do you see your products on your back end ? You would have to recreate your menus and modules if you didn't move the tables jos_menu and jos_modules
13 years 9 months ago #8822
try now, it was set on offline mode, sorry
13 years 9 months ago #8825
You have missing translation keys in your language file. You should update it and/or remove customization of views which might be different with the current version.
