Hyperlink product to detail product Page & Importing Product Characteristics
8 years 5 months ago #256259
-- Joomla version -- : 3.6.4
-- PHP version -- : 5.4.45
-- Browser(s) name and version -- : firefox 36.5
First
Clicking on product list hyperlinks to category or filter page instead of "Product Detail Page" or add to "Cart".
Also, want to add add to cart and remain on the product listing page here. every time i click cart, it takes me to check out.
Kindly point me to where to configure hyperlink on products.
Second
I have developed a catalogue of products characteristics - color, weight, size, volume, language etc which i will like to import into the characteristic table. How best can i do this?
  • Thank you received: 13549
8 years 5 months ago #256281
1. You can change the option "After a product is added to the cart" of the HikaShop configuration.
Regarding the product page URL, I couldn't understand what you want to do.
2. You can use the CSV import as explained here:
www.hikashop.com/support/documentation/73-hikashop-import.html
I would recommend to first configure a product like you want as an example, and then export it via the "export" button of the products listing.
8 years 5 months ago #256455
Where can i change this?
  • Thank you received: 747
8 years 5 months ago #256460
DACOG wrote: Where can i change this?
As Nicolas said, in the HikaShop configuration: -> System -> Configuration -> tab Main -> Cart.
www.hikashop.com/support/documentation/5...onfig.html#main_cart
8 years 5 months ago #256507
Problem solved. thanks.
loading
