Affiliate for certain products or exclude certain products
  • Thank you received: 9
6 years 2 months ago #302984
-- HikaShop version -- : 4.0.2
-- Joomla version -- : 3.9
-- PHP version -- : 7.2
Hi guys,
I will probably need a feature in the near future to exclude some products from an affiliate.
It would be great to have affiliate groups and add products in there.
Some products it is ok to give 10% but others may be more or less
Maybe some digital products 50%.
Would it not be good to have more flexibility?
I used affiliate WP (Woocommerce) and they have on each product an option for different fee's.
Thanks for the last couple Hikashop updates.
The last versions have made the checkout and the backend so much better.
Great work guys!
  • Thank you received: 13533
6 years 2 months ago #303004
Thank you.
Since we allow already different fees per partner, I'm not sure how we would do what you're talking about. Because if the partner has his fee, and the product has its fee, what fee are we supposed to use ? Maybe we could have an option to have the fee per products or the feed per partner and switch between both modes.
How does your affiliate WP handles that ?
6 years 2 months ago #303019
They have per product the option:
1. Rate type - Default - % or €)
2. The input of the rate, so how much % or euro
3. Deactivate from affiliate checkbox (most important I think)
They also have per-user different settings.
So i would think that if it is on default it uses the persons rating.
If it is on custom it overrides the users setting for custom affiliate (or in configuration a choice which one is more important :-)
Setting per product:
www.dropbox.com/s/ashy4qlm5vojiz9/Scherm...%2011.43.56.png?dl=0
User:
www.dropbox.com/s/v4foma299ht9565/Scherm...%2011.48.31.png?dl=0
You see here directly the referal url and that is a nice one.
It took me time to find that one. show it in partner page would be great.
Adding a partner in partner view would be good to i think :-)
6 years 2 months ago #303130
Thank you for your feedback. We'll take these into account when we improve the affiliate system.
6 years 2 months ago #303131
I think that this will be a great extra feature.
For now, it is no problem for me I think/hope.
After the new checkout checkbox of the address and make this easier I am really relieved and are updating old hikashops.
So now it can be a crazy difficult flexible checkout and super simple and easy.
That is awesome!
