Problem with add to card on IE8
  • Hikaserial Subscription Hikashop Business
14 years 2 months ago #9172
I have a small problem with add to card on IE8.
Pleas look to the avi file.
File Attachment:
File Name: Hikashop_ie8.zip
File Size:1,679 KB
  • Thank you received: 13545
14 years 2 months ago #9173
Could you do a screenshot of the tab checkout of the configuration of HikaShop ?
Also, do you have the joomla cache activated ?
www.theartofjoomla.com/joomla-caching-explained.html
14 years 2 months ago #9185
Thank you for your reply very much.
The joomla cache is off.
I forgot about one detail.
Normally it works great in IE8.
But try:
1. create account,
2. login to the new account with option "remember me"
3. try to buy something ==> the problem is appearing.
14 years 2 months ago #9200
We couldn't replicate the problem on our end with the same settings (ie8, joomla 1.5, new account->login with remember me->try to buy on a product page). However, that kind of problem is usually caused by the cache of the module by joomla. Could you make sure that the system cache plugin is disabled as well as the cache config on your configuration ?
14 years 2 months ago #9222
Could you look to my site?
www.dobrycad.pl/
I will send you login and password in privet message.
Thank you in advance.
14 years 2 months ago #9229
I just tried on your website and didn't had the problem either. It worked as expected. It worked while logged in with the remember me, without it, logged out, etc.
I used IE 8.0.6001.18828
Do you have the problem on your end with the account you gave me ?
loading
