Importing products - variants import problem
  • Thank you received: 17
11 years 7 months ago #98225
I exported my products from my current hikashop on joomla 2.5.9, to reimport them in my new build joomla 3.
Products imported with no problems. Variants claim to have imported with errors but do not show up #in the characteristics.
One line from the errors is listed below :)
I include the variants from one product as an attachment below. You will notice it makes a lot of extra columns which are what gives the error below :
The column 'sport pro options' is not in the list of possible columns : product_parent_id | product_name | product_description | product_quantity | product_code | product_published | product_hit | product_created | product_sale_start | product_sale_end | product_delay_id | product_tax_id | product_type | product_vendor_id | product_manufacturer_id | product_url | product_weight | product_keywords | product_weight_unit | product_modified | product_meta_description | product_dimension_unit | product_width | product_length | product_height | product_max_per_order | product_access | product_group_after_purchase | product_min_per_order | product_contact | product_last_seen_date | product_sales | product_waitlist | product_layout | product_average_score | product_total_vote | product_page_title | product_alias | product_price_percentage | product_msrp | product_canonical | price_value | price_value_with_tax | price_currency_id | price_min_quantity | price_access | files | images | parent_category | categories_namekey | categories_image | categories_ordering | categories | related | options. The column data was ignored
It says it ignores the extra columns and imports, but the part codes cannot be found anywhere.
Joomla 3, latest hikashop business, oceans17.co.uk
Last edit: 11 years 7 months ago by rikatos.
  • Thank you received: 13378
11 years 7 months ago #98443
Before importing the CSV, you need to create the characteristics via the menu Products->Characteristics. Otherwise, the system won't be able to import properly the variants.
11 years 7 months ago #98488
Are you telling me that I need to re-create every single variant ? I have over 400 variants, and these variants have their own characteristics x 4 each minimum !
If so I think I may cry ! That would be totally crazy.
11 years 7 months ago #98686
That's not what I'm saying.
I'm saying that you need to create the characteristics, not the variants of the products.
You can ind your characteristics via the menu Products->Characteristics.
11 years 7 months ago #99173
Ahh ok, but still, that means in my case about 400 characteristics to be made, and its not a big store, but at least I dont have to re-create the 1600 or so variants.
Its a hollow yayy but a yayy none the less. I guess Im off to do the painful excercise of creating those 400 characteristics manually then...ouchy still :)
11 years 7 months ago #99181
To do that more easily, you could simply export the table hikashop_characteristic and import it on your new website via phpmyadmin.
That will take 2 minutes.
11 years 7 months ago #99309
exported the table, changed table name prefix in export to the new one, imported. Most worked so thats great!
Just a side note, the import didnt seem to bring in the same order for variants listing, so now I have variants with mixed up orders and unfortunately the variants dont seem to have a way of ordering them still apart from the way they are created , so big ouchy still as I now need to step through each product, check the ordering of the variant and delete them all and re create them if they are wrong:(
