Problem with italian provincie visualization
7 years 4 months ago #273570
-- url of the page with the problem -- : www.notteconvenienza.it/ecommerce1/index...kashop&ctrl=checkout
-- Joomla version -- : Joomla! 3.4.3 Stable [ Ember ] 2-July-2015 16:00 GMT
-- PHP version -- : 5.5.38
Hi all
I'm trying to implement the user registration at checkout; I deleted all the countries in the user registration country field: I just left Italy, but at that point I cant have loaded the italian cities displayed (seeem like ajax won't start or something like that); I have seen it works if I leave a country before Italy because maybe the onchange triggers the load of the italian cities.
Is there a chance to have it fixed? Thanks in advance as usual...
Vivaldo
  • Thank you received: 13376
7 years 4 months ago #273592
That's because Italy is not the default country for the country field.
So you need to edit the country field, make sure that Italy is selected as default and save the custom field settings once.
Then, the state field will be able to load the states of the default country.
The following user(s) said Thank You: moscavi
