Free Products checkout problem
7 years 3 months ago #307111
-- HikaShop version -- : 4.1
-- Joomla version -- : 3.9
-- PHP version -- : 5.6
Hi, I'm creating file shop:
some products are free,but in checkout process we have Payment, I suggest to add if condition for checkout process that when the product is free it dose not show the Payment step and just complete the order.
in normal i have this process for shoping cart and checkout :
cart - login - payment - end
i need only for free products :
cart - login - end
7 years 3 months ago #307113
That should already be the case.
There is some code in the HikaShop checkout system to remove the payment when the total is equal to 0.
Note that if your product price is 0.00001 then it's not considered equal to 0 even though the rounded total will display at 0.00. So that could explain why you see the payment method selection.
Otherwise, we would need more information on the situation to be able to help as we can't reproduce the issue on our end.
6 years 6 months ago #316183
Hi, I encounter the same problem, without having changed anything (as far as I now).
I could give you some information ans login credentials to have a further look. How can I do this in a way nobody else can see this info?
Kind regards, Hans
6 years 6 months ago #316185
You can send that along with a link to this thread via our contact form:
6 years 6 months ago #316199
It's not a bug you have.
It's just that you have a price set for your product. The price is set to 0.00001 for that product.
It's rounded to 0.00, but since it's not 0, then the payment methods selection is displayed on the checkout.
Remove the price for that product and the payment methods won't appear:
monosnap.com/file/7Xcg0t8ajVsHI7t32sktWzDhqRHgA2
6 years 6 months ago #316203
Thanks Nicolas! I never would have figured this out myself. Of course I read the history of this topic, but I didn't realize that I actually had to click the Edit button to see the price of 0.00001.
Thanks again, also for your quick response.
