Guest Checkout - problem with data range required in Guest Checkout
5 years 1 month ago #311728
-- HikaShop version -- : 4.2.1
-- Joomla version -- : 3.9.12
-- PHP version -- : 7.2.14
Hello, I have found a problem with proper presentation of Guest Checkout when in Checkout Workflow in Login block, option “Show Submit Button” is set as NO. In this case additionally Name, Username, Password, Verify Password are added to the range of data required from the Client in Guest Checkout.
Please find below how it looks with proper range of data - when “Show Submit Button” is set as YES:
Please find below how it looks with improper range of data - when “Show Submit Button” is set as NO:
Is it possible to have proper range of data also when “Show Submit Button” is set as YES ?
Greg
  • Thank you received: 13372
5 years 1 month ago #311762
Could you provide some screenshots of the settings under the "Checkout" tab of the HikaShop configuration so that we can reproduce the issue on our end (as I wasn't able to when I tried).
5 years 1 month ago #311776
Hi Nicolas, I checked additionally the settings on the Prostar template and it turned out that the problem was caused by overriding the show_block_login.php view
sorry for the confusion
Greg
