product volume as liquid volume
9 years 3 months ago #211363
-- Joomla version -- : 3.4.3
-- PHP version -- : 5.4.42
-- Browser(s) name and version -- : Firefox.39
-- Error-message(debug-mod must be tuned on) -- : no error message
Hi I have a large number of products that have the volume as ml, liters, etc. How can I add these liquid volumes and not weight to my products?
thanks for your help
9 years 3 months ago #211365
A good solution can just be to use a product "volume" custom field but if your use a shipping method different than "Manual" shipping method, you'll still have to configure a weight/dimensions for your product.
9 years 3 months ago #211445
Thanks. I have a number of small issue like this, for example I have a product that comes in two sizes: A & B, box A contains 20 items, Box B contains 50 items, each are different physical size, have a different product number and a different price. How can this be managed? can this and the Volume (liquid) be managed as custom fields together?
I have 8000 products on the list so its not possible in the short term to do associated products only as updates after the list is imported I think?
9 years 3 months ago #211452
The real question is how do you want it to be managed ? For example you can manage it by using a "box size" characteristic so that you'll be able to set different weight/dimensions/volume but you won't be able to correctly manage the quantity of your product (for each variant sold the quantity will be reduced by 1).
9 years 3 months ago #211717
Yes I can see that as a problem. It may make more sense to add the weigh or volume of the item in the description rasther than in a seperate field. Currently weight and volume are in a seperate coloumn of my spreadsheet / pricelist. so was hoping to import as CSV without changing thousands of fields. If I did this then I have many products that fall into shipping weights of for example 500g, 1Kg so would it be possible to set blocks of weights for shipping?
I appreciate the help
9 years 3 months ago #211774
Hi !
Yes but, you'll have to create one manual shipping method for each block by using the options :
- Price
- Minimum price
- Maximum price
Through your shipping method configuration page.
Last edit: 9 years 3 months ago by Mohamed Thelji.
The following user(s) said Thank You: Harlequin
