Products ordered by model number on invoice and shipping bill
8 years 2 weeks ago #297959 by marcovanlennep
-- Joomla version -- : 3.8.11
I am trying to get the products ordered by model number on the invoice and shipping bill.
I know it is in Display-->View-->Order-->Invoice.php and believe it is in this piece of text around line 105:
<th class="title" width="60%">
<?php echo JText::_('PRODUCT'); ?>
</th>
<?php if ($this->config->get('show_code')) { $colspan++; ?>
<th class="title" ><?php echo JText::_('CART_PRODUCT_CODE'); ?></th>
<?php } ?>
As I don't know PHP I think I need to put somewhere ASC to get the products ordered by model number. Can anybody help me and tell me where to put it, Please?
8 years 1 week ago #297990 by marcovanlennep
8 years 1 week ago #297991 by Jerome
Modifying the HikaShop core to change that behavior will work but is not something recommended since you will lost your modification with the next update.
Using a view override is much more appreciate for that.
Regarding your first message and the modification ; unfortunately no, it is not there that part that you want to customize.
If you want to change the sort ; you must do it before that line
foreach($this->order->products as $product) {
Before in the "foreach" block, all your products will be display one by one ; following the current order in the array or products.
Please note that such kind of modification in the view requires PHP knowledge.
The usage of the PHP function "usort" could be interesting for your case.
us3.php.net/manual/en/function.usort.php
And do not hesitate to use debug function like "var_dump" to display content of variable ; it helps to know the content of product objects and find which elements you can use for your code.
us3.php.net/manual/en/function.var-dump.php
Time to create page: 0.202 seconds
