Problem with custom plugin
7 years 9 months ago #260719
-- HikaShop version -- : 2.6.4.
-- Joomla version -- : 3.6.5
-- PHP version -- : 7.0.5
Hi guys!
I have just rewrite your Hikashop google products plugin for another product search provider. I was developing it on one of my localhost and successfully made it works. But when I installed it on live site something went wrong. Installation - no problem, enable and set up plugin - no problem, but when I want to download manually xml file there is problem. And absolutelly don't know why, because on first localhost where I developed it is working, but on live site and even on other localhosts not... My plugin is here in attachments.
If you can just look what my problem is, I would be really grateful! Thanks!
7 years 9 months ago #260757
Ok, now I know where can be the problem. I have copied install componet files com_hikashop_2.6.4 and added my custom plugin - added to back/extensions/plg_heureka_products and to update file back/helpers/update.php. And with this package I upgraded existing Hikashop. So my plugin was added as well and it's working. So problem is just with way of how to install it...
I guess that I am just missing one more thing - where else get Hikashop know about my custom plugin to make it works?
Right know I can do the same on my live site and it will works, but I would prefer (even for the future custom plugins) how install just plugin without need to upgrade whole component...
  • Thank you received: 4028
7 years 9 months ago #260760
Just install your plugin via Joomla.
And let Joomla structure load the plugin and make it interact with HikaShop.
7 years 9 months ago #260836
Hi Jerome,
I worked it out. It was some bug with my Hikashop. After reinstall it works like it should.
Thanks!
