Discount for every 3 products added - not minimum of 3
  • Thank you received: 11
6 years 8 months ago #292664
I need to add a discount for multiples of 3 to a product - not at quantity 3 the discount kicks in. Our product price per unit is $12.99.
We want to set it up so that for every 3 items ordered, the price defaults to $29.99 for those 3. And then for each item thereafter it would charge the regular $12.99 until they hit another 3 items in the same order, in which case that set of 3 would automatically go to $29.99 as well.
E.G. Order of 3 items - $29.99
Order of 5 items - $55.97
Order of 6 items - $59.98
We also need each bundle of 3 to still show up as 3x separate on the packing slip ideally.
  • Thank you received: 647
6 years 8 months ago #292688
If I understand you well, I think you want set a specific condition in Coupon in order to automatically load the discount :
Note especially the red bordered options, for fit your needs.
Plus, you can restrict on which product(s) you can apply the Coupons.
Hope this will fit your needs.
Last edit: 6 years 8 months ago by Philip.
6 years 8 months ago #292718
Right, but won't that kick the coupon into action at a quantity of 3 and then every subsequent addition will still get the discount ie. 4 products at the total discount instead of 3 at discount and 1 at full? I need the discount to kick in for EVERY 3 not at 3.
So we need this:
Quantity of 1 = $12.99
Quantity of 2 = $12.99 x 2
Quantity of 3 = $10.00 x 3
Quantity of 4 = $10.00 x 3 + $12.99 x 1
Quantity of 5 = $10.00 x 3 + $12.99 x 2
Quantity of 6 = $10.00 x 6
Quantity of 7 = $10.00 x 6 + $12.99 x 1
And so forth.
6 years 7 months ago #292725
That's indeed quite different, to have a such way to process discount maybe you have to look in a specific discount plugin because HikaShop isn't able to manage this.
I think about a little trick but it's up to you if that fit your needs, follow my example :
Discount number 1 :
for 3 products => 23 %
- 12.99 $ X 3 = 38,97 $ > 23 % > 30 $
Discount number 2 :
for 4 products => 17,26%
- 12.99 $ X 4 =51.96 $ > 17.26 % > 42.99 $
Discount number 3 :
for 5 products => 13,82%
- 12.99 $ X 5 =64,95 $ > 13.82 % > 55.98 $
Discount number 4 :
for 6 product => 23 % as Discount number 1
etc
If this solution don't fit your needs, I see another possibility contact one of our Partner page to create a specific custom for your needs.
Sorry for this return.
Last edit: 6 years 7 months ago by Philip.
6 years 7 months ago #292802
Ok. That's not a bad alternative - obviously we'd have to build it out to a finite level since infinite is not achievable. If we come up with a solution that works then I will post it here in case anyone else needs it.
