Problems with characteristics when importing CSV
13 years 3 months ago #22158
I am having problems with my characteristics setting when importing CSV-files, files that I imported at the beginning of my project works with the size characteristic but other files (made the same way) the heading disapears in the product view and the size doesn't change when I change it in the drop down.
I also just noticed that the heading has disapered on the files that worked before after I upgraded to a newer version. I used to have the headline in fron of the ID and size behind but now I only have size in front of and behind the ID
Size option works: www.fashionyouknow.com/klaeder/product/s...category_pathway-356
Size option not working: www.fashionyouknow.com/abercrombie-fitch...e-fitch-hoodies-herr
I also get this message on some products: The default value of one of the characteristics of that product isn't available as a variant. Please check the characteristics and variants of that product
  • Thank you received: 13372
13 years 3 months ago #22170
The title on the product page isn't updating because there is a problem with the way you imported your products/variants.
It's hard to say more without having a look at the CSV but there must be an error in it. Also, note that if you have several characteristics with the same values, it can sometimes cause a conflict during the import. If so, you should make sure that each value is unique and try again after updating the CSV.
For the last message, it's also because of the CSV. It means that in the CSV, your product has values of characteristics which do not match with a variant of that product in the CSV.
13 years 3 months ago #22230
This is an example of the file that worked before the update of hikashop to newer version:
product_name;product_description;product_code;product_parent_id;product_weight;product_keywords;product_meta_description;price_value;storlek;images;categories;price_currency_id
Armani kalsonger;Armani Underkläder Herr;334549;;1;Armani Underkläder Herr;Armani Underkläder Herr;85;;334549.jpg;2,16,15,355,356,31,363;150
;;334549 M;334549;;;;;m;;;
;;334549 L;334549;;;;;l;;;
;;334549 XL;334549;;;;;xl;;;
;;334549 XXL;334549;;;;;xxl;;;
;;334549 XXXL;334549;;;;;xxxl;;;
And here is an example of one that never worked properly with characteristics
Lacoste Piké Dam;Fin Pikétröja Dam;339078;;1;Lacoste Pikétröja Dam;Lacoste Pikétröja Dam;125;;339078.jpg;2,15,16,49,513,656,765;150
;;339078 xs;339078;;;;;XS ;;;150
;;339078 s;339078;;;;;S;;;150
;;339078 m;339078;;;;;M;;;150
;;339078 l;339078;;;;;L;;;150
;;339078 xl;339078;;;;;XL;;;150
Products without chracteristics work without any problems
Last edit: 13 years 3 months ago by Andreas_Sweden.
13 years 3 months ago #22233
Could you do a screenshot of the characteristic storlek edition screen ?
I see that you use both upper and lower case or the characteristics values... It might come from that...
13 years 3 months ago #22236
I have tried to change the upper and lower case but not had any success, it still remain the same.
And the thing is that the first example used to work until I upgraded, after the upgrade I lost the headline for the product and just got the ID and size (but the size characteristivs still works)
13 years 3 months ago #22241
I think I understand. You didn't specify the default value for the characteristic in the main product data of your CSV.
It should be:
Armani kalsonger;Armani Underkläder Herr;334549;;1;Armani Underkläder Herr;Armani Underkläder Herr;85;M;334549.jpg;2,16,15,355,356,31,363;150
13 years 3 months ago #22247
Thanks, I will give it a try amd get back with the result
13 years 3 months ago #22295
That worked the sizes are now working on the ones I tested it on, however I am still missing the headlines and just get the Product Code and size in the headline supposed to be headline, product ID and size, the headlines went away after upgrading could it be related to this: www.hikashop.com/en/support/forum/4-how-...customer-can-se.html if there has been changes made in the code to the new version?
13 years 3 months ago #22322
Did you edit the show file of the view product before updating maybe ?
We had changed the way the name is displayed so if you had edited the view before updating, such problem could be happening.
13 years 3 months ago #23156
All problems solved with characteristics s, m, l etc but I am still having trouble with sizes on shoes where it is numeric, I get the drop down menu but the size doesen't change in the order or the headline.
13 years 3 months ago #23179
Could you give a link to the product page where the size doesn't change ?
13 years 3 months ago #23422
Sorry for the delay, here is one example www.fashionyouknow.com/barnklaeder2/prod...category_pathway-895
I also get: The default value of one of the characteristics of that product isn't available as a variant. Please check the characteristics and variants of that product
13 years 3 months ago #23436
Could you try the modification explained on that post: www.hikashop.com/en/support/forum/3-bug-...cs-issues.html#23222
That might solve the problem.
13 years 3 months ago #23484
It didn't help :(
13 years 3 months ago #23546
The problem on this product www.fashionyouknow.com/barnklaeder2/prod...category_pathway-895 is that the default value of the characteristic in your CSV is not available as a variant. So HikaShop cannot pick it up to generate the dropdown properly. That's why the refresh is not working and that's why you have the error message
So the problem comes from the CSV.
