HikaShop Filter Module help!
12 years 1 month ago #68596
how can i implement the way the HikaShop Filter Module works as on the demo page demo.hikashop.com im stuck !
  • Thank you received: 403
12 years 1 month ago #68608
Hi there,
Just take a look at your joomla's module and you'll see that there is a filter module already prepared for hikashop (it's named 'Search').
Just configure this module by specifying a filter (that you can create in Display>Filters) and a menu (you have to write a menu id there) and publish it.
12 years 1 month ago #68610
where do i find this module? i looked in extensions -> module manager but cant see any modules called search?
12 years 1 month ago #68612
That's the place. You may not have the last version of Hikashop.
Another option is to configure directly a filter. Take a look at the documentation ;)
12 years 1 month ago #68619
ive installed the latest version, the only search i see was in the plug in manager are you sure its supposed to be in modules? The only one in modules is Hika Shop Filter module. I have enabled the search in plugins it does work but it just shows a list, i was hoping to display the images as well as on the demo page
thanks for the reply
12 years 1 month ago #68624
My bad, it's the right module you're seeing.
About the display it depends of the menu you linked to the module.
This module have to be configured to display the layout you want.
12 years 1 month ago #68628
thanks thats what I need help with. I want a user to enter a search variable from the home page and it then searches for products and displays the results with the images. however im having difficulty setting this up
12 years 1 month ago #68633
What the menu id you specified? Try to find this module and configure it to display product the way you want.
If you need more help, please give a screenshot of your filter configuration :)
12 years 1 month ago #68636
the menu id is what is confusing me ? what is this for? here is a screenshot
12 years 1 month ago #68638
That's it. The field is empty in your case. You have to look at your menu listing (in Hikashop) and select (or create) a menu with all of your products inside and with the layout you want.
Then, Just look at the id of this menu (on the right in the menu listing) and specify this id in the filter configuration.
12 years 1 month ago #68646
thanks for that i allocated the menu id but now when i try to place the module on a page doesnt appear, ive tried different templates including the default joomla ones and tried various positions but it doesnt appear. I attach a screenshots. In hika3 png the module is supposed to be in postion 4 but as you can see its not there. It is enabled as shown in hika5.png
  • Thank you received: 13375
12 years 1 month ago #68813
I don't see why it wouldn't display.
In order for it to display you need to :
have filters
make it display on all menus
have it enabled
have it access allow you to see it (public)
have it in a valid position of your template
make sure that caching is disabled on your website
That's all I can think of.
12 years 1 month ago #69953
We're have problems with this too. We just want something that functions the same way as the demo. Actually, will be very happy with the software if we can get the same result as the demo.
12 years 1 month ago #70090
You should know that you can access the backend of the demo website with the login/password demo
That will allow you to see how we configured the filters and the filter module.
If you have more issues even though you did the same as the demo website, please post some screenshots of the options of the filters/filter module and we'll be able to tell you what's wrong.
  • Thank you received: 49
10 years 6 months ago #153742
hi
read few topics about filter but dont find or missing answer. my problem when i publish filter it publish in content but i dont need this.I publish module only for one menu but filter show in another places of site. how to remove filter copy from content?
Last edit: 10 years 6 months ago by master_b.
10 years 6 months ago #153797
To remove that you have to disable the option "Display filters" in the menu / module settings.
The following user(s) said Thank You: master_b
10 years 6 months ago #153819
tnx
its possible change this setting for 80 menus at "one click" ?)
upd. system-config-display-Display filters on product listing-No
10 years 6 months ago #153833
Indeed, the option in your menu / module should be set on "inherit" so changing the value in Configuration > Display > Products > "Display filters on product listing" allow you to change the value at one click.
Time to create page: 0.123 seconds
